Pagination issue
I am having an issue with pagination. PageCount shows null when I am trying to do pagnination which I do not understand
ERROR: No data found for item-index: “0”
“title”: “Data Scientist, Machine Learning”,
“path”: “/data-scientist-machine-learning-teamgohealth-4704923”,
“remote”: false,
“company_name”: " #TeamGoHealth",
“company_slug”: “teamgohealth”,
“company_logo_url”: “https://startup.jobs/logos/10004”,
“location”: “United States”,
“location_html”: “<a class="link z-10" href="/locations/illinois">Illinois, <a class="link z-10" href="/locations/united-states">U.S.”,
“_tags”: [
“Data Science”,
“Machine Learning”
“objectID”: “4704923”,
“_highlightResult”: {
“title”: {
“value”: “Data Scientist, Machine Learning”,
“matchLevel”: “full”,
“fullyHighlighted”: false,
“matchedWords”: [
“data”,
“scientist”
“company_name”: {
“value”: " #TeamGoHealth",
“matchLevel”: “none”,
“matchedWords”:
@spencerbf, if what you posted is what HTTP Request node returns then there is no more pages to go through. You do not need to use pagination.
Hey @ihortom,
Welcome to the community :raised_hands:
When using the $pageCount option it will show null in the UI as the workflow has not run so it doesn’t know what the pagecount is, If you can share the workflow you are using we can take a look at it and see what might be missing.
Hi @ihortom The response above was from the first http request node, and then when I run the 2nd HTTP request node I get the error I shared above. @Jon here is my workflow below. Thanks for both of your help.
I have worked it out. Thanks for your help.
