Pass variables using MCP Client Tool without LLLM
Hello!
I am trying to move all the tools used by an agent to a MCP server.
The problem is that now, when the agent calls the tools, some variables like IDs are passing using N8N variables, not being created by the agent.
Here is an example:
Is it possible to pass this variables without having to insert them dynamically in the Prompt?
Or I need to wait for a next update to allow this?
Thank you!
Hey @Disowned-factory, have you found a solution?
Nope, I hope the team launch an update to allow this
