The idea is:
Enable workflow setting for execution data prune
My use case:
I have a workflow that listen to my mail inbox every minute to detect and triage automation workflows. this generates a lot of exectuion and I want to prune them based on timeout.
My challange is that
- I’m not the only one using this self-hosted n8n, and this is not the only workflow, so I can’t simply update the environment variable to change the global prunning setting ( as suggested here : Execution data | n8n Docs)
- I can not simply rely on success or failure of the workflow, since even the success flow may contain troubleshooting data when my workflow is not working as I expected.
If we can enable something in the workflow settings that can work similarly with the EXECUTIONS_DATA_MAX_AGE and EXECUTIONS_DATA_PRUNE_MAX_COUNT similar to server setup, that allow workflow to override the server settings if it’s set to more strict ( e.g. global level 180 day, workflow level 3 day, then 3 day is in effect, if global is 180 day, and workflow level 360 day, then 180 day is in effect, similarly for max count)
