Performance issue of the N8N workflow when need to operate more than 50 000 data
Hello community!
I have the issue with my N8N workflow which retrieves the more than 50 000 elements from the external API and save them to the CRM.
WHEN
I run the workflow and Node retrieves the 50 000 Contracts from External API
THEN
Workflow hanging after 10 000 elements and can’t finish successfully.
Here is the workflow:
N8N Version: 1.17.1
Running n8n via Docker
Operating system Linux
Hi @Radik_Balagutdinov
Try splitting the load by using a split in batch node with a subflow to process the data in smaller batches.
There is a couple of examples on the forum already, so you should be able to find one. :slight_smile:
