Description:
I’m running n8n on Docker behind Nginx on a VPS with the domain n8n.[domain_name].io, attempting to authenticate with YouTube using OAuth2. I’m facing an ERR_SSL_PROTOCOL_ERROR and the OAuth Redirect URL keeps including port 5678 and shows https://n8n.[domain_name].io:5678/rest/oauth2-credential/callback
. Despite troubleshooting, the issue persists, and I need help identifying the root cause and resolving it.
Environment
- n8n Version: 1.81.4
- Docker Version: Latest
- Nginx Version: 1.22.1
- VPS: Hostinger
- OS: Ubuntu 22.04
Problem
The redirect URI should be https://n8n.[domain_name].io/rest/oauth2-credential/callback
(port 443, HTTPS default), but n8n persists in using https://n8n.[domain_name].io:5678/rest/oauth2-credential/callback
, causing ERR_SSL_PROTOCOL_ERROR during authentication.
This is my docker-compose.yml configuration:
version: '3'
services:
n8n:
image: n8nio/n8n
restart: always
ports:
- "5678:5678"
environment:
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_BASIC_AUTH_USER=[user]
- N8N_BASIC_AUTH_PASSWORD=[password]
- N8N_HOST=n8n.[domain_name].io
- N8N_PROTOCOL=https
- N8N_PATH=/
- N8N_WEBHOOK_URL=https://n8n.[domain_name].io/
- VUE_APP_URL_BASE_API=https://n8n.[domain_name].io/
- N8N_RUNNERS_ENABLED=true
volumes:
- ~/.n8n:/home/node/.n8n
And this is my Nginx configuration:
server {
server_name n8n.[domain_name].io;
proxy_connect_timeout 1200;
proxy_send_timeout 1200;
proxy_read_timeout 90m;
send_timeout 1200;
client_max_body_size 5G;
add_header Access-Control-Allow-Origin *;
location / {
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Forwarded-Port 443;
proxy_set_header Host $host;
proxy_set_header Connection "upgrade";
proxy_http_version 1.1;
chunked_transfer_encoding off;
proxy_buffering off;
proxy_cache off;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/n8n.[domain_name].io/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/n8n.[domain_name].io/privkey.pem;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
server {
if ($host = n8n.[domain_name].io) {
return 301 https://$host$request_uri;
listen 80;
return 404;
Request for Help
I need advice on:
- Why n8n continues to include port 5678 in the redirect URI despite correct environment variables and resets.
- How to force n8n to use
. - Any known bugs in n8n 1.81.4 or Docker configurations causing this.
- Additional debugging steps or configuration changes I might have missed.
Please provide insights or suggestions. Thank you!
