Hi everyone,
I’m working on a RAG setup using n8n with PostgreSQL + PGVector and facing a few issues:
1. Performance & token usage
Even with low Top-K (e.g. 10), response times are very high (minutes) and token usage becomes extremely large.
- How can I reduce token usage and ensure only relevant context is passed?
2. Top-K / Limit behavior
It seems like the Top-K setting just limits the number of rows (e.g. 10, 20, 30).
If relevant data is outside this range, it won’t be found.
It feels like the system is not ranking by similarity but just limiting results.
How exactly does Top-K work in PGVector? Should it always return the most similar results?
3. Same results for different queries
No matter what I ask, I often get the same Top-K results.
What could cause identical results for different queries?
Could this be a query embedding or workflow issue?
Thanks for any help.
