Pin favourite apps and nodes, or sort based on use
The idea is:
Node navigation could be improved by sorting based on previous use or allowing the user to pin nodes to the top.
My use case:
For example, when I need a Salesforce node, I always have to skip Salesmate (a node I have never used and likely never will). Within Salesforce, I typically use the “Perform a query” node, but I have to navigate or filter by keyword to access it.
It would improve user experience.
I’m afraid it’s outside my realm of expertise, but if I can help, I will.
