Please could someone help me with my training I am stuck. I am doing the QS101 n8n Quickstart
Sorry Deepankar I found it
Hi Deepankar, I found the reason why I couldn’t get the value right for true and false that was causing the error in the first place. If you look at the output here you will see that there is no count for “True” but 30 for “False”
And I suspect this is where I am getting it wrong
are you able to assist me please?
Deepankar do you know where I can find a pdf on n8n. I can then reference the pdf in my llm before having to reach out to you? Many thanks Craig
The true branch is empty because the condition never matches, not because the data lacks processing rows. Your false branch still shows rows whose orderStatus is processing.
In the first condition both sides are orderStatus pasted twice, and they are not the same text. The left side has a space between the two expressions, the right side does not, so one side becomes “processing processing” and the other “processingprocessing”. Those are never equal, so all 30 items go down the false output.
Use a single condition and delete the second one:
Left value, in Expression mode: {{ $json.orderStatus }} once, not pasted twice.
Operator: String, is equal to.
Right value: switch that box from Expression to Fixed and type processing, with no quotes and no extra space.
Run Execute step again. processing rows should land on true, and booked (and any other status) should stay on false.
There isn’t one official PDF of the whole product. For this step, the course card in your screenshot is the spec, and the help icon on the IF node opens that node’s docs.
@Brokes You’re close, the course step itself is fine, it’s the dragging. When you drop a field onto a box that already has an expression in it, n8n doesn’t replace it, it adds the new one after a space. So your left side now gives the status twice, like “processing processing”, which never matches, and all 30 go to False.
The right side shouldn’t be dragged at all. The course has you type processing there as plain text, so switch that box to Fixed. And delete the second condition with the empty value1, because with AND both have to be true and an empty box never is.
So clear the left box, drag orderStatus in once, type processing on the right, and Execute step again. Handy for the rest of the course too: if a box already has something in it, clear it before you drag.
@Brokes
This is definitely wrong
You only need one entry. I see double entry here
Thanks a million Sir.
Thank you so much!
Brokes, the + button is easy to miss because it can sit at the edge of the credential dropdown rather than beside the field you’re looking at. If it still isn’t showing, try clicking directly in the Credential dropdown and choosing Create New, which does the same job. Also check you’re on the Header Auth Generic Auth type screen, not the node’s main Authentication list, since the option only appears in the right place. Worth confirming whether the Academy expects the credential named exactly as shown, too.
