- n8n version: 1.73.0
- Database (default: SQLite):: none so it defaulted to SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): main
- Running n8n via (Docker, npm, n8n cloud, desktop app): self hosted on render, but i dno which one I used, in the settings in render I have this in the build command: pnpm install --frozen-lockfile; pnpm run build
- Operating system:: windows
This is the error i keep getting in the logs:
Error handling CollaborationService push message
Error: Error handling CollaborationService push message
at Push.<anonymous> (/opt/render/project/src/packages/cli/src/collaboration/collaboration.service.ts:37:6)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
"code": "invalid_union_discriminator",
"options": [
"workflowOpened",
"workflowClosed"
"path": [
"type"
"message": "Invalid discriminator value. Expected 'workflowOpened' | 'workflowClosed'"
ZodError: [
"options": [
"workflowOpened",
"workflowClosed"
"path": [
"type"
at Object.get error [as error] (/opt/render/project/src/node_modules/.pnpm/[email protected]/node_modules/zod/lib/types.js:55:31)
at ZodDiscriminatedUnion.parseAsync (/opt/render/project/src/node_modules/.pnpm/[email protected]/node_modules/zod/lib/types.js:183:22)
at parseWorkflowMessage (/opt/render/project/src/packages/cli/src/collaboration/collaboration.message.ts:34:9)
at CollaborationService.handleUserMessage (/opt/render/project/src/packages/cli/src/collaboration/collaboration.service.ts:50:27)
at Push.<anonymous> (/opt/render/project/src/packages/cli/src/collaboration/collaboration.service.ts:34:5)
Not sure why its happened, but I know it wasn’t there when I initially ran the server on render.
Honestly, no idea what I’m doing here or what I’m seeing, so happy to pay for your time ot help me solve this
