Hey can anyone help me with this I am on windows and facing issue when pnpm build . Would be great if someone had faced this, and can guide to resolve.
Hey @med3d ![]()
I believe the build is failing on Windows when running the popularity-cache-marker step. If you have already updated your Node.js to LTS version and the issue is still persistent, I can recommend below 2 alternatives:
- Use WSL2 and and run the build inside Ubuntu/Debian. This avoids most Windows-related path and script issues.
- Run it on Docker
