Possible EventEmitter memory leak detected
How can i increase [Queue] MaxListener ? Because i am facing with below error:
Execution 271561609 (job 790) finished successfully
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 global:completed listeners added to [Queue]. MaxListeners is 10. Use emitter.setMaxListeners() to increase limit
at genericNodeError (node:internal/errors:984:15)
at wrappedFn (node:internal/errors:538:14)
at _addListener (node:events:598:17)
at Queue.addListener (node:events:616:10)
at Queue.on (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/bull/lib/queue.js:374:14)
at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/bull/lib/job.js:523:18
at new Promise ()
at Job.finished (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/bull/lib/job.js:499:12)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at /usr/local/lib/node_modules/n8n/src/workflow-runner.ts:393:6
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 global:failed listeners added to [Queue]. MaxListeners is 10. Use emitter.setMaxListeners() to increase limit
at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/bull/lib/job.js:524:18
at new Promise ()
Version: n8n:1.94.1
Mode: Queue
Redis: 1 master, 3 replicas with version 8.0.2
DB: postgresql
