- **n8n version:1.68.0
- **Database (default: SQLite):Postgres
- **Running n8n via (Docker, npm, n8n cloud, desktop app):npm
- **Operating system:AWS AMI 2023
Please share a description of your issue Thanks!
Sorry,
out of reasons I don´t understand the text is not visible in the initial post. O_o
When using SELECT in Posgres node it´s possible to set a limit or return all data.
However it would be convenient, if an OFFSET could be set/add within the UI, which seems not to be possible right now. Of course it´s possible to write a sql query to achieve this.
Thanks for the update
Sounds like a feature request then. Lemme switch that so you can give it a vote!
