Postgres (Supabase) upsert: “Column to match on not found in input item”
I am trying to use the Postgres v2 node (Insert or Update / upsert) to sync data from Google Sheets into a Supabase/Postgres table (public.exposure_control).
I want to match existing rows using the Link (and ideally also AFF ID) column(s). The input items already contain Link and AFF ID fields and the table has the same columns (there is also a unique index on ("AFF ID", "Link")).
However, the Insert or Update operation keeps failing with “Column to match on not found in input item”, even when I switch Mapping Column Mode to Map Each Column Manually and explicitly map Link to {{$json["Link"]}} and AFF ID to {{$json["AFF ID"]}}.
“errorMessage”: “Column to match on not found in input item. Add a column to match on or set the ‘Data Mode’ to ‘Define Below’ to define the value to match on.”,
“errorDetails”: {},
“n8nDetails”: {
“nodeName”: “Insert or update rows in a table”,
“nodeType”: “n8n-nodes-base.postgres”,
“nodeVersion”: 2.6,
“resource”: “database”,
“operation”: “upsert”,
“time”: “04.12.2025, 16:51:46”,
“n8nVersion”: “1.119.1 (Self Hosted)”,
“binaryDataMode”: “default”
“AFF ID”:
“3728431”,
“Link”:
null,
“GEO”:
“TR”,
“Initial position”:
null,
"Current position ":
null,
“Casino/Betting/Cryptro”:
null,
“Teamlead”:
“ANASTASIA”,
“MANAGER/TEAM”:
“Polly”,
“TL Comment”:
null,
“Position de facto”:
null,
“Check by Traffic Control (date)”:
null,
“DEAL”:
“CPA 100 BL 1”,
“Comments 15.07”:
null,
“Comments November”:
“аппрув, пока нет сайта”,
“Bonus Mentioned (amount, percentage)”:
null,
“Актуальная рефка?”:
null,
“Комменты Ира/Денис”:
null,
“Отправлено в работу?”:
false,
“Исправлено?”:
false
“AFF ID”:
“3721111”,
“Link”:
https://www.example.com/en/”,
“GEO”:
“CA\nNZ\r\nDE\nAT\nFR\nFI\nNO”,
“Initial position”:
“2/3”,
“6”,
“Casino”,
“Teamlead”:
“ANASTASIA”,
“MANAGER/TEAM”:
“Lexie”,
“TL Comment”:
null,
“0”,
null,
“DEAL”:
“50% RS”,
“Comments 15.07”:
null,
“в ревью все норм, инфа корректная”,
null,
null,
null,
false,
“Исправлено?”:
false
Hello @hellodiima, welcome to the :n8n: comunity!
If you can share a sample workflow, it will be easier to help..
Until then, looking at the output:
you might need to handle that case where Link is null or empty..
Thank you so much for your help!
You were absolutely right: some of my input items had Link = null (or empty), and those were causing the issue. Once I filtered out rows with an empty Link before calling the Postgres node, everything started working as expected.
