Hi there
I have a problem when using postgres database. I successfully setup the owner user, yet when I try to create additional users I have a problem. From what I understand it’s because my postgres instance (hosted on Azure) doesn’t support to encode using MD5 “could not compute MD5 hash: disabled for FIPS”.
P.S.: the exact same setup with sqlite works fine.
I see in the logs:
2025-03-04T14:21:58.916977688Z ResponseError: An error occurred during user creation
2025-03-04T14:21:58.916981788Z at UserService.inviteUsers (/usr/local/lib/node_modules/n8n/dist/services/user.service.js:163:19)
2025-03-04T14:21:58.916984888Z at processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-03-04T14:21:58.916987788Z at InvitationController.inviteUser (/usr/local/lib/node_modules/n8n/dist/controllers/invitation.controller.js:69:48)
2025-03-04T14:21:58.916990688Z at handler (/usr/local/lib/node_modules/n8n/dist/decorators/controller.registry.js:93:24)
2025-03-04T14:21:58.916993388Z at /usr/local/lib/node_modules/n8n/dist/response-helper.js:110:26
2025-03-04T14:21:58.916996088Z
2025-03-04T14:21:58.916998488Z could not compute MD5 hash: disabled for FIPS/home/LogFiles/2025_03_04_lw1mdlwk0002XW_default_scm_docker.log (https://blockloads-sectionslab-auto-qa.scm.azurewebsites.net/api/vfs/LogFiles/2025_03_04_lw1mdlwk0002XW_default_scm_docker.log)
- n8n version: 1.81.4
- Database (default: SQLite): postgres
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: Azure
