Private Instance - Loses Connection Commonly
I’m commonly getting Connection Lost errors when trying to add, test, update workflows. It doesn’t seem to be for any particular reason. I have a very beefy server so not sure what’s going on. Here’s a video of the error flow: CleanShot 2025-10-18 at 15.44.18 · CleanShot Cloud - It won’t retrieve the page until about 35 seconds later.
Any help is appreciated and willing to share anything else that might help solve the issue. Thanks in advance!
Connection Lost
  • n8n version: 1.1115.3
  • Running n8n via (Docker, npm, n8n cloud, desktop app): docker - coolify
  • Operating system: Ubuntu
I think , my issue is similar . i am new user who is doing some POC . i am using very simple workflow using the same n8n version as you and OS : windows . even i have subscribed on this tool . getting You have a connection issue or the server is down.
n8n should reconnect automatically once the issue is resolved.
