Problem activating workflow
Hello , I am using n8n self hosted version. I have creaed a work flow with a few seatable trigger.
However,after i activate the workflow, from time to time, i receive this error. " problem activating workflow"
may i know what is wrong with my setup?
Hi @Benjamin123
Have you tried splittinf the workflow? So each part is a seperate workflow.
I’ve never tried having 1 workflow with so many trigger nodes. This might be the issue.
Hello , I think it might be the issue. After i try to create the workflow with only 1 trigger node, i am able to "active " the workflow
That is odd you should be able to have mutliple triggers in the same workflow. I know if you duplelicate a trigger node rather than adding it from the menu it can cause issues, Any chance that was what you did here?
