Problem HTTP REQUEST
Good evening everyone, I’m new to n8n and automations, I’m making a request for N8N to wait to continue the flow in typebot, but I’m making a mistake in the HTTP REQUEST to continue the flow, what link would it be? I’m putting it wrong!
Hey @aspirante,
Welcome to the community :raised_hands:
It is hard to say what the issue is as the image quality isn’t great, Are you able to share a screenshot, the text output of the HTTP Request node and the JSON for the workflow itself so we can look into it further?
Obrigado por responder!, então não coloquei nenhum codigo no JSON, só mandei o link pro bot do typebot para continuar fluxo, mas não continua
Hey @aspirante,
Would you be able to translate that to English, We are only able to provide in support in English and I worry that if I google translate it I may lose some context.
Thanks for replying!, so I didn’t put any code in the JSON, I just sent the link to the typebot to continue the flow, but it doesn’t continue and follows the flow without waiting for the response from n8n
I don’t know how typebot works, what is it you are actually trying to do?
