Problem in IMAP node with Roundcube
Can’t connect IMAP node to Roundcube. Error: getaddrinfo ENOTFOUND https://webmail.freehostia.com/.
Workflow
json
Copy
“nodes”: [
“parameters”: {},
“type”: “n8n-nodes-base.emailReadImap”,
“name”: “Email Trigger (IMAP)”
n8n via: npm
OS: Windows
Question
How do I find the correct IMAP host for Roundcube? Current host (https://webmail.freehostia.com/) is not working.
Hey Wael,
The issue here is that https://webmail.freehostia.com/ is just the webmail interface (used by your browser), not the actual IMAP server.
For IMAP, you’ll need the mail server’s raw hostname — usually something like:
mail.freehostia.com
Try this instead:
Host: mail.freehostia.com
Port: 993
Secure: Yes (SSL/TLS)
Also make sure your login credentials (email + password) are correct, and that IMAP is enabled in your mailbox settings.
If mail.freehostia.com doesn’t work, check Freehostia’s documentation or contact their support — some hosting providers use a different mail hostname or require specific ports/auth settings.
Let me know if that helps!
Dandy
