Problem in node ‘AI Agent‘ Cannot read properties of undefined (reading 'reduce')
Cannot read properties of undefined (reading ‘reduce’)
I have node AI Agent.
The version of the node is the latest. AI Agent node version 3.1 (Latest
Randomly, sometimes I have an error instead of a normal text answer from the model. The error looks like this
“Problem in node ‘AI Agent‘
Cannot read properties of undefined (reading ‘reduce’)”
I have a very large context.
This error is not always (around 3 percent of teh times)
The retry on fail feature does not work.
Can anyone please help me with this bug)&&&7
  • n8n version: 2.4.3 self-hosted
  • Database (default: SQLite): mongo db ut it is separate. Only model node is connected to the AI Agent node
welcome to the n8n community @vika87
I’d trim the context before it reaches the AI Agent, make sure any optional inputs are never undefined, and update n8n to the latest version. In cases like this, the error is usually triggered by oversized context or inconsistent input structure rather than the model itself.
Hi @vika87 Welcome!
Let me help you. First use GPT-5 models they got the best context window so that even your large data can be handled by those models, also use a good model provider if you are not using like Openrouter, and basically using a GOOD model would easily fix this problem so go with it.
