Problem in node ‘Execute Command‘
I am trying to make a workflow that downloads CSVs from a site and convert it into a SQLite Database but it errors out making it fail to run at Sync to Database.
Problem in node ‘Sync to Database‘
Command failed: node /home/gwashark/Documents/CSVtoSQLITE/index.js “/home/gwashark/Documents/e621/Temp/pools.csv” “e621.db” “pools”
NOTE: ? is Execute Command
  "errorMessage": "Command failed: node /home/gwashark/Documents/CSVtoSQLITE/index.js \"/home/gwashark/Documents/e621/Temp/pools.csv\" \"e621.db\" \"pools\"\n",
  "errorDetails": {},
  "n8nDetails": {
    "nodeName": "Sync to Database",
    "nodeType": "n8n-nodes-base.executeCommand",
    "nodeVersion": 1,
    "itemIndex": 0,
    "time": "2/4/2026, 1:38:37 PM",
    "n8nVersion": "2.6.3 (Self Hosted)",
    "binaryDataMode": "filesystem",
    "stackTrace": [
      "NodeOperationError: Command failed: node /home/gwashark/Documents/CSVtoSQLITE/index.js \"/home/gwashark/Documents/e621/Temp/pools.csv\" \"e621.db\" \"pools\"",
      "    at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/ExecuteCommand/ExecuteCommand.node.ts:102:12)",
      "    at processTicksAndRejections (node:internal/process/task_queues:105:5)",
      "    at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1069:8)",
      "    at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1250:11)",
      "    at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1685:27",
      "    at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2328:11"
Expected:
✓  Connected to the SQLite database.
✓  CSV headers: [ 'id', 'name', 'created_at', ... ]
✓  Table 'pools' created successfully.
✓  CSV file successfully processed.
✓  Database connection closed.
✅  Conversion complete! Check 'e621.db' for your database.
  • n8n version: 2.6.3
  • Database (default: SQLite): SQLITE
  • n8n EXECUTIONS_PROCESS setting (default: own, main): main(?)
  • Operating system: Debian 12 Bookworm
Hi @gwashark have you tried changing your “Sync to Database” command to the correct path on the Docker container’s filesystem
something like:
node /usr/src/n8n/data/CSVtoSQLITE/index.js “/usr/src/n8n/data/e621/Temp/pools.csv” “/usr/src/n8n/data/e621.db” “pools”
My paths are setup as
Host (Outside the Container) Container (Inside the Container)
/DATA/AppData/n8n /home/node/.n8n
/home/gwashark /home/gwashark
So I don’t think that would work.
now Understood your path now @gwashark, you can either install all the nodejs dependencies (sqlite3 etc.) which will be here according to your path
and it needs to be inside your n8n docker container globally. OR modify the workflow and run the conversion through n8n’s inbuilt nodes and not an external script. This might be the reason causing the issue.
Thanks for your help, I tried Ai again and now we are on track.
