Problem in node ‘n8n‘ Invalid URL
I am trying to link an external n8n workflow to my AI Agent via Call n8n Workflow Tool. When connecting and using the end letter/digits combination from the workflow URL as defined in your guide I get the message: Invalid URL
What is the error message (if any)? Problem in node ‘n8n‘ Invalid URL
Please share your workflow -
Error details
From n8n
Error code
ERR_INVALID_URL
Other info
Item Index
0
Run Index
0
Node type
n8n-nodes-base.n8n
Node version
1 (Latest)
n8n version
1.66.0 (Cloud)
  • n8n version: 1.66.0
Welcome to the community @Crazydarkman13 !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
What Base URL do you have in the “n8n account” credentials and where do you have your n8n instance hosted?
base URL: n8n.io - Workflow Automation
cloud hosted
When you say ‘external workflow’ do you mean a workflow that runs on an another instance? That’s not supported by the subworkflow tool. You’d probably need to set up a webhook/HTTP Request Tool for this.
Still learning n8n but what I mean is when I set two different workflows within the same project and use the last letters/digits as reference ID one another. Does it make sense? Just to be clear the sit one the same project within the same URL in n8n cloud.
Hey I’m having the same problem here. Is there any fix yet?
