Problem in node ‘Pinecone Vector Store1‘ Vector dimension
When executing a workflow, this error always occurs at the end of my Pinecone Vector Store
The number for Vector dimension varies depending on which file I select when downloading from Google Drive
“nodes”: [
“parameters”: {
“operation”: “download”,
“fileId”: {
“__rl”: true,
“value”: “1Gs4O9m-sg3MyVw3IFLkRineN4rMsvoUE”,
“mode”: “list”,
“cachedResultName”: “manual_A5_62317V5_maeuse_ameisen_abwehr_6-23.pdf”,
“cachedResultUrl”: “https://drive.google.com/file/d/1Gs4O9m-sg3MyVw3IFLkRineN4rMsvoUE/view?usp=drivesdk
“options”: {}
“type”: “n8n-nodes-base.googleDrive”,
“typeVersion”: 3,
“position”: [
80,
0
“id”: “25beed33-be99-41c3-88da-aa1acaa6bf68”,
“name”: “Google Drive”,
“credentials”: {
“googleDriveOAuth2Api”: {
“id”: “W0RiEUtsMCD88gU6”,
“name”: “Google Drive account”
“parameters”: {},
“typeVersion”: 1,
“position”: [
-80,
0
“id”: “dc278e6a-f59c-4fb6-8597-3df8388a55ac”,
“name”: “When clicking ‘Test workflow’”
“parameters”: {
“dataType”: “binary”,
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.documentDefaultDataLoader”,
“typeVersion”: 1,
“position”: [
320,
180
“id”: “98034e54-59cd-4668-888b-900f5e5bb5d8”,
“name”: “Default Data Loader”
“parameters”: {
“mode”: “insert”,
“pineconeIndex”: {
“__rl”: true,
“value”: “rag-chatbot”,
“mode”: “list”,
“cachedResultName”: “rag-chatbot”
“options”: {
“pineconeNamespace”: “rag”
“type”: “@n8n/n8n-nodes-langchain.vectorStorePinecone”,
“typeVersion”: 1,
“position”: [
240,
-20
“id”: “83fd25b4-65dd-4ced-80b9-7f8aceb070cf”,
“name”: “Pinecone Vector Store1”,
“credentials”: {
“pineconeApi”: {
“id”: “ipjR4QzOTdtu2NEg”,
“name”: “PineconeApi account”
“parameters”: {
“modelName”: “models/embedding-001”
“type”: “@n8n/n8n-nodes-langchain.embeddingsGoogleGemini”,
“typeVersion”: 1,
“position”: [
100,
260
“id”: “97457208-ba0e-4c40-a49d-02bc01ace6ec”,
“name”: “Embeddings Google Gemini”,
“credentials”: {
“googlePalmApi”: {
“id”: “xPmIM2IcnMM5w5S3”,
“name”: “Google Gemini(PaLM) Api account”
“parameters”: {
“chunkSize”: 1000000,
“chunkOverlap”: “=0”,
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.textSplitterRecursiveCharacterTextSplitter”,
“typeVersion”: 1,
“position”: [
420,
400
“id”: “2b089381-97d1-4e20-ab13-53ed5ec60a2f”,
“name”: “Recursive Character Text Splitter”
“connections”: {
“Google Drive”: {
“main”: [
“node”: “Pinecone Vector Store1”,
“type”: “main”,
“index”: 0
“When clicking ‘Test workflow’”: {
“main”: [
“node”: “Google Drive”,
“type”: “main”,
“index”: 0
“Default Data Loader”: {
“ai_document”: [
“type”: “ai_document”,
“index”: 0
“Embeddings Google Gemini”: {
“ai_embedding”: [
“type”: “ai_embedding”,
“index”: 0
“Recursive Character Text Splitter”: {
“ai_textSplitter”: [
“node”: “Default Data Loader”,
“type”: “ai_textSplitter”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “a772b07cb916db0ace570744fd3566138e7a670babc4139cf5504bff9e78d14a”
  • n8n version: Newest
  • Operating system: Win 11
Hey Emanuel,
please put your JSON code inside a code block
like this
Your problem seems to be more related to the configuration in Pinecone, rather than a problem with the workflow.
But share it with us in a code block and let’s see what we can find!
Create an index in Pinecone that has 1536 dimensions (and probably cosine metric). When you access that Vector Store, up or down, use an Embeddings OpenAI node set to text-embedding-3-small. Then your requests will match your index.
Hey @Emanuel_Lasche do you still need help with this?
