hi i have a problem with the slack trigger and i cant figure it out
webhooks are set up incoming and outgoing. outgoing works fine. i can post to my channel.
but incoming i have a problem and i cant figure out what this is. i also dont have enough knowledge to solve this with scripting.
“errorMessage”: “Cannot read properties of undefined (reading ‘type’)”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “1.71.3 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“TypeError: Cannot read properties of undefined (reading ‘type’)”,
" at WebhookContext.webhook (/usr/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Slack/SlackTrigger.node.ts:335:36)“,
" at Workflow.runWebhook (/usr/lib/node_modules/n8n/node_modules/n8n-workflow/src/Workflow.ts:1276:29)”,
" at Object.executeWebhook (/usr/lib/node_modules/n8n/src/webhooks/webhook-helpers.ts:258:39)“,
" at processTicksAndRejections (node:internal/process/task_queues:95:5)”,
" at /usr/lib/node_modules/n8n/src/webhooks/test-webhooks.ts:117:25"
I’m sure someone can help me with this. Thanks in advance
