Problem in node ‘Summarization Chain‘ Cannot read properties of undefined (reading 'pageContent')
Getting error Problem in node ‘Summarization Chain‘ Cannot read properties of undefined (reading ‘pageContent’)
When using the summarisation chain. Can’t see why?
Stack
TypeError: Cannot read properties of undefined (reading 'pageContent')
    at RefineDocumentsChain._constructInitialInputs (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]_@[email protected]_@[email protected]_@google-ai+gen_l2pdhycmx5ubucgl6yjsjdwoyq/node_modules/langchain/dist/chains/combine_docs_chain.cjs:325:31)
    at RefineDocumentsChain._call (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]_@[email protected]_@[email protected]_@google-ai+gen_l2pdhycmx5ubucgl6yjsjdwoyq/node_modules/langchain/dist/chains/combine_docs_chain.cjs:365:42)
    at RefineDocumentsChain.call (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]_@[email protected]_@[email protected]_@google-ai+gen_l2pdhycmx5ubucgl6yjsjdwoyq/node_modules/langchain/dist/chains/base.cjs:129:24)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at Object.execute (/usr/local/lib/node_modules/n8n/packages/@n8n/nodes-langchain/dist/nodes/chains/ChainSummarization/V2/ChainSummarizationV2.node.js:337:34)
    at Workflow.runNode (/usr/local/lib/node_modules/n8n/packages/workflow/dist/Workflow.js:696:19)
    at /usr/local/lib/node_modules/n8n/packages/core/dist/WorkflowExecute.js:656:53
  • n8n version: self hosted latest beat version
  • Database (default: SQLite): sq lite
  • Operating system: Unbuntu
Hi @Robm, I am sorry you are having trouble.
I just tried running your chain with a bit of dummy data and it completes fine for me:
This is with the latest n8nio/n8n:ai-beta pulled just now. Can you confirm if you’re still seeing this problem with the latest image? If so, can you provide an example JSON dataset sent to your Summarization Chain using which the problem can be reproduced?
