I have tried to use the slack channel history search function to search the message. However, it returns as follows:
//ERROR: UNKNOWN ERROR - check the detailed error for more information
Slack error response: {“ok”:false,“error”:“not_in_channel”}//
I have checked as i should grant the searching history access on slack side. And attached is the screenshot of my setting.
Could someone help me?
Hey @tomtsang!
Welcome to the community
Did you add the bot to the channel n8n-testing
? The bot needs to be added in the same channel whose history it needs to read.
Let me know if you still face any issues
Thanks. I have added the bot in the same channel. (I am using n8n-testing for testing and there are some message in the slack alr)
So i wonder what’s goes wrong.
These are the steps I followed:
- Add
channels:history
and channels:read
scopes to the bot.
- Reinstall the Slack App on the workspace.
- Run the Channel > Get All operation to get the channel ID.
- Copy the Channel ID.
- Set the operation to History and in the Channel field, paste the Channel ID.
- Toggle Return All to true.
Here’s a screenshot of the final node:
