Problem manually installing community nodes
I successfully installed community nodes on n8n installed on Railway
n8n version: 1.31.2
Database: Postgres
n8n EXECUTIONS_PROCESS: main
Running n8n via: Docker
But they don’t appear in the editor, I had already implemented it in another installation and it worked perfectly
I checked the error below in the logs:
2024-03-07T13:16:02.502Z | error | Failed to renew license: renewal failed because current cert is not initialized “{\n stack: ‘Error: renewal failed because current cert is not initialized\n’ +\n ’ at C._renew (/usr/local/lib/ node_modules/n8n/node_modules/@n8n_io/license-sdk/dist/LicenseManager.js:29:3103)\n’ +\n ’ at C.renew (/usr/local/lib/node_modules/n8n/node_modules/@ n8n_io/license-sdk/dist/LicenseManager.js:29:2983)\n’ +\n ’ at License.renew (/usr/local/lib/node_modules/n8n/dist/License.js:175:28) \n’ +\n ’ at LicenseService.renewLicense (/usr/local/lib/node_modules/n8n/dist/license/license.service.js:66:32)\n’ +\n ’ at LicenseController.renewLicense (/usr/local/lib/node_modules/n8n/dist/license/license.controller.js:28:35)\n’ +\n ’ at handler (/usr/local/lib/node_modules/n8n/dist/ decorators/registerController.js:78:78)\n’ +\n ’ at /usr/local/lib/node_modules/n8n/dist/ResponseHelper.js:103:32\n’ +\n ’ at newFn ( /usr/local/lib/node_modules/n8n/node_modules/express-async-errors/index.js:16:20)\n’ +\n ’ at Layer.handle [as handle_request] (/usr/local/lib /node_modules/n8n/node_modules/express/lib/router/layer.js:95:5)\n’ +\n ’ at next (/usr/local/lib/node_modules/n8n/node_modules/express/lib/router /route.js:144:13)',\n file: ‘license.service.js’,\n function: ‘mapErrorMessage’\n}”
Hi @Claudio_Balbino
Welcome back :slight_smile:
Can you tell us what you are doing exactly?
I assume you are doing this through the UI? Can you show?
Have you refreshed the page etc.?
Follow the steps described in the url below
Adding commands to the Dokerfile
RUN mkdir ~/.n8n/nodes
WORKDIR ~/.n8n/nodes
RUN npm i n8n-nodes-chatroot
RUN npm i n8n-nodes-text-manipulation
I check through the logs that the nodes were installed, but they don’t appear when I search for any of them
Hi @Claudio_Balbino Can you share your dockerfile?
FROM n8nio/n8n:latest
USER node
RUN npm i n8n-nodes-chatwoot
ARG PGPASSWORD
ARG PGHOST
ARG PGPORT
ARG PGDATABASE
ARG PGUSER
ENV DB_TYPE=postgresdb
ENV DB_POSTGRESDB_DATABASE=$PGDATABASE
ENV DB_POSTGRESDB_HOST=$PGHOST
ENV DB_POSTGRESDB_PORT=$PGPORT
ENV DB_POSTGRESDB_USER=$PGUSER
ENV DB_POSTGRESDB_PASSWORD=$PGPASSWORD
ARG ENCRYPTION_KEY
ENV N8N_ENCRYPTION_KEY=$ENCRYPTION_KEY
CMD [“n8n start”]
I haven’t been able to solve this problem yet, any suggestions?
