Problem on JSON with Default data loader?
I have a problem between the input and the output of my node “insert Data store”.
The default data loader handle my json as a blob file and create an element for each line instead of 1 with metadata and the other one with pageContent.
Exemple:
input:
 "pageContent": "Comité RSE du 28 janvier",
 "metadata": {
    "source": "notion"
    "title": "Comité RSE",
output:
 "metadata": {
     "source": "blob",
     "blobType": "application/json",
     "line": 1,    ...
 "pageContent": "notion",
 "metadata": {
     "source": "blob",
     "line": 1,    ...
It is mandatory to use a loader but i’m not able to configure it correctly as in any case it splits all my values
 "metadata": {
     "source": "blob",
     "line": 1,    ...
 "metadata": {
     "source": "blob",
     "line": 1,    ...
  • n8n version: 1.106.3
  • Database (default: SQLite): simple memory
  • Operating system: Mac os
Hi Romain_vermeeren, I hope you’re doing well. I wanted to reach out because I am currently experiencing the same issue that you mentioned. Have you found any solutions to this problem? I am also struggling with it and, unfortunately, I have not been able to find any effective solutions myself. Any insights you could share would be greatly appreciated.
Hello ! Unfortunately i’m still stuck at this step even if i try another source of data.
