and for second API passing the function node results as input. When I do node[“Function”].json, I only see one item in the input passed to second API as supposed to all items.
Input to the second API body expression is
{{ { “receipts”: $node[“Function”].json } }}
Is your first node returning more than one result and on your second node at the top does it have a number?
Which nodes are you using and are you able to send some screenshots of the output of the function and the output of the second node? A full snip of the node pop up box is best and you can edit out anything personal / sensitive.
Looking at the screenshot of the Function node, it seems like it is returning 3205 items. If you want to use all the items in a single request, you will have to change the data structure. You can use the Item Lists node for that.
Currently, your data structure is as follow
The first node returns 5 items. We use the Function node to combine all the items and return all the values in a single item. If you execute both the nodes, you will be able to see the number of items returned by them.
You will have to use a similar function node to combine and return a single item, and pass that to your HTTP Request node.
