Problem running: workflow Lost connection to the server
Using cloud-based n8n on my Win10 laptop.
Can’t run workflows at all.
Keep getting Lost connection to the server fault popup.
I tried Incognito, deleting cookies, disabling McAfee extension.
It seems that something is blocking the websocket connection because mobile works fine.
Does anyone came across this problem?
Thanks
Hi @goldman.idan , what error messages do you see in your browser dev tool’s console. On the laptop, does it work with another browser?
Please confirm this is n8n cloud, not an instance hosted on Hostinger, for example.
Khem
Hi Khem,
This Is the Dev tool error:
o1420875.ingest.us.sentry.io/api/4503960699273216/envelope/?sentry_version=7&sentry_key=3a848d77e104fa41f2735a1d3a1ef8e7&sentry_client=sentry.javascript.vue%2F9.42.1:1
   Failed to load resource: the server responded with a status of 403 ()
It works fine from my mobile
