Problem running workflow. Lost connection to the server(In cloud).
Facing this error. Have tried clearing cache, restarting workspace, incognito window, updating version. was working previously and facing this issue from yesterday.
Hi @Divya92 Welcome!
If you have tried all of those i think the issue can be related to the server side, as you have tried what you could on your side, consider reaching out to support from one of these:
welcome to the n8n community @Divya92
One thing I’d add is a quick sanity check to confirm whether this is affecting just this workflow or the instance as a whole. If you create a brand new workflow with only a Manual Trigger and try to execute it, does it show the same “Lost connection” behavior?
This can help narrow things down before opening a support ticket and gives you a clearer signal of where the problem is happening.
