Problem running workflow - WhatsApp App ID already has a webhook subscription
*The WhatsApp App ID 1854510272117304 already has a webhook subscription. Delete it or use another App before executing the trigger. Due to WhatsApp API limitations, you can have just one trigger per App.
I consistently receive the above message whenever I set up my WhatsApp Trigger. I can send and receive messages with my personalized WhatsApp AI, but when I try to activate the workflow, I get the error mentioned above! Are there any people who can help me with this? Who have experienced the same issue — and managed to solve it?
Encountering the same problem here
I don’t think anyone on the form has an answer for our problem!
Clearly is says that you are using in another workflow?
That is the problem. I only use the workflow in the n8n-cloud environment and that is the only error I get.
Then is better to check in your Meta account too see which Url is registered as webhook.
Mybe someone else is using it…
