Problem to download PDF from URL using HTTP Requests
I I searched previous topics but didn’t find a direct solution.
I can’t extract the PDF using HTTP Request from some URLs, like this one: https://www.mpba.mp.br/sites/default/files/biblioteca/diariojustica/20250523.pdf
I always get a timeout. Help me do it.
  • Running n8n via n8n cloud
Hi @rpimenta welcome to the community!
The link isn’t publicly accessible, so it’s expected that it won’t work in n8n either.
It’s because https://www.mpba.mp.br/ only allows connection from certain locations, so if you jump on a VPN in br, your get access, but because n8n cloud is hosted I think " Azure Germany West Central" you won’t be able to connect without a proxy if the site allows it.
Hope this helps.
@King_Samuel_David :clap:t2:
