Hello,
i try to install n8n with Docker on my Raspberry pi B 2.0. I’ve install Raspberry Pi OS and i’ve succeeded to install Docker.
Now, i tried to install n8n with instruction on the n8n documentation but i’ve problem and i don’t find the solution.
when i used the command below, i’ve error message :
docker run -d -it --rm --name n8n -p 5678:5678 -v n8n_data:/home/node/.n8n docker.n8n.io/n8nio/n8n
Errore Message :
Unable to find image 'docker.n8n.io/n8nio/n8n:latest' locally
latest: Pulling from n8nio/n8n
docker: no matching manifest for linux/arm/v6 in the manifest list entries.
See 'docker run --help'.
certainly an incompatibility with the ARM v6 processor… But is there a solution?
Justin
