Problem webhook in test mod
in n8n the webhook at the beginning of my workflow automatically goes into test mode. I may put it in “production” mode, but it returns to this mode. I don’t know what to do anymore. Thank you for your help.
hello @Laurent34
The webhook will be in production mode once you activate the workflow. Test mode will be activated only when you run the workflow manually
