Hello everyone! I would like some information about a flow that I created in n8n, integrated with the “z api”. I don’t know what’s happening because the flow appears to be working perfectly, but I don’t receive messages on my WhatsApp number. I configured the HTTP Request node and the Hebhook, but I don’t know if I used the correct expression, since I couldn’t produce the inputs that I needed. Thank you!
Could you provide the workflow json for more details/context?
I will send the json code, I don’t know how to send it in document format. Thank you for your attention!
What is the error or output of the http node for z api?
No error! In the tests everything is normal, but I don’t receive the LLM automation
Please rephrase? Don’t receive the automation? Or message?
What does the output look like for the http request? Perhaps it expects a different phone # format, typically with a + in front with the country code. I don’t see that there.
I’m sorry sir but I do not understand.
