Problem with baserow using multiple choices using tally
Whenever i try to input multiple-choices answer on a new row in baserow using tally, it doesnt let me.
  "errorMessage": "Bad request - please check your parameters",
  "errorDescription": "ERROR_REQUEST_BODY_VALIDATION",
  "errorDetails": {
    "rawErrorMessage": [
      "400 - {\"error\":\"ERROR_REQUEST_BODY_VALIDATION\",\"detail\":\"The provided select option values ['030213f7-542a-449e-9b28-790d604326d3', 'b1d982c1-1e5a-471e-b731-da09c4bbccb1'] are not valid select options.\"}"
    "httpCode": "400"
  "n8nDetails": {
    "nodeName": "Baserow",
    "nodeType": "n8n-nodes-base.baserow",
    "nodeVersion": 1,
    "resource": "row",
    "operation": "create",
    "time": "08/08/2024, 16:28:05",
    "n8nVersion": "1.53.1 (Cloud)",
    "binaryDataMode": "filesystem",
    "stackTrace": [
      "NodeApiError: Bad request - please check your parameters",
      "    at Object.baserowApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Baserow/GenericFunctions.js:31:15)",
      "    at processTicksAndRejections (node:internal/process/task_queues:95:5)",
      "    at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Baserow/Baserow.node.js:182:40)",
      "    at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:19)",
      "    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:673:51",
      "    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1086:20"
My workflow at the moment is just extracting the answers from tally and inputing them on baserow
## Share the output returned by the last node
<!-- If you need help with data transformations, please also share your expected output. -->
    "id": 19,
    "order": "20.00000000000000000000",
    "Nome": "asdasd",
    "Nº de telefone": "+551231213111",
    "Pessoas na mesa": "11",
    "Produtos pedidos": [],
    "Nota para atendimento": [],
    "Quer participar de ofertas?": []
Note that this is the output WITHOUT the multiple-choices answer,
im very new to n8n so any form of help is appreciated :slight_smile: thank you very much!
Hey @m_og,
Welcome to the community :cake:
Can you share what your multi select option looks like in Baserow? It looks like Baserow doesn’t like the data being sent so we may need to change something in the workflow.
Are you able to also share the workflow here that you are using?
this is the workflow im working on, as you can see, it extracts data from tally, and puts into baserow, however, when it comes to multiple-choices answers, i cannot get a workaround for it
