A boolean from a webhook (true or false) from a JSON body. Then send to a node HTTP (body JSON), false does not work and sends an empty body. True works
No error. Just the false is not returned. I need to change it to 1 or 0 for this to work.
Please share the workflow
Data :
"data": {
"test": true,
"test2": false
- n8n version: 0.172.0
- Database you’re using : SQLite):
- Running n8n with the execution process [own(default), main]:
- Running n8n via Docker:
