Hi, what im trying to do is the following. A human recieves a PDF, opens it and check that 6 fields match with corresponding columns in a spreasheet (there is an id match to determine the row). If 6 fields data match, human procedes to send an email from a template using some of those fields, and attaching the PDF.
On the automation side, the workflow triggers when a new file is added to folder which is then downloaded to n8n and uploaded to LlamaPArse to extract info in markdown. Then i pass the mardown to the information extractor agent which extracts the 7 fields i need. One i use it to bring the google sheet row i need. After some data transformation on both branches (sheet and info extracted from pdf) i feed a Compare Datasets with the following.
"Nombre de la campaña": "AAA",
"Nombre de talento": "BBB",
"Dirección de mail": "[email protected]",
"Condición de pago": 60,
"Empresa": "DDD",
"Monto total sin IVA": 1800000
"Pais NEW": "DDD",
"Monto NEW": 1800000,
"Acción": "AAA",
"Influencer": "BBB",
"Dias": 60,
"Contacto": "[email protected]"
From this compare dataset node, i expected to branch the workflow. If there are cero errors, then proceed with email. If there is some kind of difference, then go back to pdf generator (possible by email remarking the differences).
Thing is it outputs the following
In A only Branch (1 item)
"Empresa": "DDD",
Same Branch
No output data in this branch
Different Branch
In B only Branch (1 item)
"Pais NEW": "DDD",
"Acción": "AAA",
"Dias": 60,
"Contacto": "CCC@CCC"
Im getting no error message, compare datasets is not working as i understand it should
I pasted it here buy revealed to much company data si id rather not post it if not needed.
- n8n version: N8N cloud latest beta stable
- Database (default: SQLite):
- Operating system:
