Problem with connecting to GPT API
Hey, I just tried to connect my GPT Secret Key to the OpenAPI credentials in n8n. Even though I entered the secret key correctly, I’m getting this error: ‘Couldn’t connect with these settings’ and when I click ‘More Details’ it says ‘Unauthorized’.
I’ve tried generating new secret keys multiple times and carefully copied them again, but it still doesn’t work. For context: I installed n8n on my own VPS using the one-click install feature through my VPS dashboard (my VPS is with Hostinger). Can anyone help me solve this problem?
Don’t input the organization and try again.
Did you really create the organization N8N GPT in your openAI?
ahhh so that thing affected to this problem? i thought so..
so where i can change the account type?
If you really are organization and you don’t need to change
Often users mis-type that field as a name.
You might need to make sure what’s the account type in your openAI and align with the settings from there.
Oh, I just realized I only needed to delete the ‘N8N GPT’ field in the Organization section. Sorry, I didn’t fully get what you meant earlier, but the issue is resolved now. Thank you!
