Problem with dynamic form in n8n
hi can is posible to input my data in option radio button automatic ? because sometime the data email its not static 3 email, but can lower or maybe more many.
obrigado :slight_smile:
Hi @Agellls, welcome!
Yes, this is possible, You can use the JSON option like this:
Then dynamically build the JSON based on your data..
Here is a working example you can start with:
thanks sir so helpfull
