Hi guys! I am trying to use ffmpeg for oga to wav conversion and having a trouble. My n8n is installed in a docker and ffmpeg is installed in a different docker. I cant execute it.
What I have tried:
Direct exection via Execute command note. n8n doesnt see the ffmpeg docker and this didnt work
HTTP request node didnt work as well
Code "{
“Image”: “jrottenberg/ffmpeg:5.1-alpine”,
“Cmd”: [“ffmpeg”, “-i”, “/data/input_audio.oga”, “/data/output_audio.wav”],
“HostConfig”: {
“NetworkMode”: “n8n_n8n-network”,
“Binds”: [“n8n_file_storage:/data”]
the output mistake is “The service refused the connection - perhaps it is offline”
Maybe I’m missing something about how you are running n8n or what you are executing, but it sounds like you are trying to run docker-in-docker.
In item #1, you said “n8n is installed in a docker” which I assume means you are running n8n in a docker container. If that’s correct, the Execute Command node would be running commands within the same container as n8n, not on the docker host. The only commands you could execute in a workflow would have to be installed in the n8n docker image.
For instance, wget is installed in the published n8n container image, so this command works wget -O - https://httpbin.org/get
ffmpeg is not installed in the n8n docker image.
In your item #2 you mentioned the HTTP Request node but the jrottenberg ffmpeg image only wraps the ffmpeg command-line to run with docker run... I don’t quite follow how you are expecting these two things to work together.
So to get this working, you could do one of these things…
Option 1
Create a modified n8n docker image, layered on top of the base (published) n8n image, with the ffmpeg command line package installed in the image.
Create a Dockerfile like this:
ARG tag=latest
FROM n8nio/n8n:$tag
USER root
RUN apk update
RUN apk add ffmpeg
USER node
Rig docker-compose.yml to build the customized image like this:
