Hello! I want to get information from rows, by the operation Get Row(s), but it doesn’t return anything. The table contains values. The node also sees the table itself, the sheet, and all the columns, but can’t retrieve their values. I think this is a bug, because the operation returned values once, but after the next run, everything was empty again. I tried deleting and reinstalling the node, but it didn’t help. Thanks in advance for your reply.
Actually, the problem is I can see a combined filter “AND” in the get row(s) in sheet node.
(Filters
Currently no items exist
Combine Filters is set to AND]
,but we cant see any condition parameters set up
This is default parametrer. I try to change to “OR“, but didn’t receive any results.
hey @batalkinkirill welcome to n8n community,
I ran same node and I got results just right
can you tell what are you getting when running this node?
