Hi n8n team,
I’m trying to connect my HelpScout account via the O2Auth.
When i click on the authorize button (helpscout page), i’m redirected to my n8n instance but i got a json error message:
{“code”:0,“message”:“The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.”,“hint”:""}
In the url path, i’m on /rest/oauth2-credential/callback
And i got the code and state params as wanted.
Information on my n8n setup
Running n8n via Docker, and my settings uses the system of queuing.
The problem is that the OAuth Redirect URL is not good for me… It results on a 404 if i let it like in the previous screenshot. I need to remove de “webhook.” in the url and tranform it to “https://n8n.mydomain.com/rest/oauth2-credential/callback”. By doing this, i don’t have a 404 error but i got the error i mentionned in my previous post. I don’t know why.
Thanks @nma, when setting the WEBHOOK_URL to another domain, I can indeed reproduce the behavior you have described. Would you be able to temporarily remove this configuration option and re-try authenticating with HelpScout?
Hi @MutedJam , it will be difficult for me. I put this settings because i got many problems with my instance who is not so powerfull and when i received a lot of webhook calls in same time, all the instance is down
If no other solution, then i will try but i try to find the source issue if possible before. Do you have an idea of what can cause this problem with this setting ?
Hi @nma - to clarify, I am not suggesting to make such a change permanently. I merely want to narrow down whether this setting is indeed the cause of the problem for you. So it would be great if you could give this a quick go during a period of low load and then revert the setting.
Hi @MutedJam,
I comeback to you on this issue because i have done an update on our n8n instances. I tried to authenticate to HelpScoot by disabling the queue mode, changing params (WEBHOOK_TUNNEL_URL and WEBHOOK_URL) and it worked. Then i came back to queue mode and still working with the token saved before.
So the issue is ok by doing that, nevertheless i think that we have an issue with thins kind of auth.
Thanks for your help !
