Problem with http request node
Hi, im trying to send to the API of MessageBird the next Parameters:
  • to (Number to send a message)
  • from (ChannelId from user of MessageBird)
  • template (template’s name from user to start conversation)
  • type (type from message, always text)
  • content (Text of the message)
I always receive this error because this parameter that the API expect to receive is a json, and the node that permit to send this paremeters don’t allow to send a json, only a parameter and her value.
The documentation from the site is here → MessageBird | API Conversations
And the URL that im trying to send the information is these →
https://conversations.messagebird.com/v1/conversations/start
I have already authenticated with the access_key, the problem is that parameter
You are not defining the content parameter. Also, you are defining the template, but that parameter it’s not in the docs.
But in the node it only lets me send parameters and their values, that’s why it gives me that error.
Hey @victormiranda!
You will have to set the content type in the Header parameter. You can set the Header parameters under the Headers section.
If i put the type content in the header i receive this error.
I need to put this inside Body Parameters, and when i put this inside i recieve this other error.
You need to add the following in the Header parameter:
Value: application/json
Same error, i can’t do anything.
Hey, can you please share the credentials via personal message? This will help me replicate the issue and provide you a solution
It work now, i add the option JSON/RAW Parameters and insert this in Body Parameters:
“url”: “https://conversations.messagebird.com/v1/send”,
“raw_url”: “https://conversations.messagebird.com/v1/send”,
“method”: “post”,
“to” : “+34XXXXXXXX”,
“channelId” : “???”,
“type” : “text”,
“headers”: {
“Authorization”: “AccessKey ???”,
“Content-Type”: “application/json”
“content”: {
“text”:“Hi there, Im Using Whatsapp”
I’m so happy ajajaja, 2 days for this, but finally it works, Thanks you for your help.
