Problem with IMAP node
Can’t connect IMAP node to Roundcube. Error: getaddrinfo ENOTFOUND https://webmail.freehostia.com/.
Workflow
json
Copy
“nodes”: [
“parameters”: {},
“type”: “n8n-nodes-base.emailReadImap”,
“name”: “Email Trigger (IMAP)”
n8n via: npm
OS: Windows
Question
How do I find the correct IMAP host for Roundcube? Current host (https://webmail.freehostia.com/) is not working.
hello @wael_hassan
you can google it :slight_smile:
