xut
June 19, 2025, 8:21am
1
As the nocoDB-nodes does not support search requests I have to use a loop over all items to check for my matches.
Here’s the logic:
I get new data (think of it as lead)
I get all entries from table (“leads”)
If there is already an entry in table 1 the process stops. (That works correct.)
When no entry is found I grab all data from table 2 (“orders”)
Now I check the new lead with the existing orders.
If the lead already orders I add it to th elead table with status “ordered”. (That works correct.)
If not I want to add the lead with status “new”.
The issue is:
Adding the lead with status “new” does not happen once but as many times as I have orders in the table.
No error messages.
**n8n version:**1.98.2
Database (default: SQLite): SQLite
n8n EXECUTIONS_PROCESS setting (default: own, main): own
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: Ubuntu
I think this will be more straighfoward
But not sure why there are two nodes of creating orders. Maybe just leave one of them.
Or use filter agian to create the orders.
xut
June 19, 2025, 9:29am
3
Thanks for the filter idea! But that part of the script works fine - but with the filter it is simpler.
There are two Add entry-Nodes to create entries in the lead table at the end:
The one at the “done” Path added with status “new”,
the other one with the status “ordered”. (The name of the node is misleading here. Sorry).
So if we find an order, we use the second one and the workflow stops.
If we do not find at the end of the 2nd loop the done-Part should create just one lead with status “new”. But it is call for as many elements as we have in the loop.
Oh yes. Forgot to mentioned that :
I use execute Once
if the first IF
node.
Because if there are multiple items. Like 3
It will cause the following part to execute 3 times
But I think you only need to execute once since you will get all the orders.
xut
June 19, 2025, 9:39am
5
I have to check for every single order if the customer in that order is the one from the lead. So execute once can’t be the solution.
But it might help on the node “add entry new”. I’ll give it a try.
Add another image for better explain it!
xut
June 19, 2025, 10:15am
7
I replace both loops with a aggregate-node and a code-node after that. This works fine.
Sadly the loop nodes seem to have a bug or something.
system
Closed
June 26, 2025, 10:16am
8
