I tring to list files from nextcloud but getting this error.
n8n and nextcloud behind the reverse proxy nginx. If disable proxy getting same error. It seems to be a n8n error.
“errorMessage”: “Method not allowed - please check you are using the right HTTP method”,
“errorDescription”: “405 - ""”,
“errorDetails”: {
“rawErrorMessage”: [
“405 - ""”
“httpCode”: “405”
“n8nDetails”: {
“nodeName”: “List a folder”,
“nodeType”: “n8n-nodes-base.nextCloud”,
“nodeVersion”: 1,
“resource”: “folder”,
“operation”: “list”,
“time”: “2025. 12. 08. 13:02:28”,
“n8nVersion”: “1.122.4 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“NodeApiError: Method not allowed - please check you are using the right HTTP method”,
" at ExecuteContext.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/node-execution-context/utils/request-helper-functions.ts:1498:10)“,
" at processTicksAndRejections (node:internal/process/task_queues:105:5)”,
" at ExecuteContext.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/node-execution-context/utils/request-helper-functions.ts:1798:11)“,
" at ExecuteContext.nextCloudApiRequest (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/NextCloud/GenericFunctions.ts:61:19)”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/NextCloud/NextCloud.node.ts:1092:21)“,
" at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1074:8)”,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1255:11)“,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1691:27”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2307:11"
- n8n version:
- Database (default: SQLite):
- Operating system:
