Problem with Philips Hue
Hi all,
I tried to connect to my Philips Hue lights using the documentation they provided: Login - Philips Hue Developer Program
This works perfect when using Postman, when I tried this in an N8N HTTP node it it doesn’t do anything but time-out. Any ideas, or tips? I do have to mention that I run N8N through Repocloud, so that might be an issue.
Could you ctl a, ctl c the workflow, click the ‘</>’ button on the forums when drafting a reply and paste the workflow into the field that appears? Will help with context.
