Can you tell me if itâs still possible with n8n to read env var from node ? I updated in v1.33.0 (but I also tested i v1.31.0) and I cannot read anymore env var from code node.
Do I know how can I fix this ? The following WF not work anymore (few months before it worked)
Digging more into my initial issue my problem comes from the fact that I use a trick to be able to use http proxy for https requests.
But since this change bellow I have sometimes some issues :
core: Apply correct hostname to redirected requests (#8674) (0e36aeb)
Is there an official solution to be able to use http proxy for HTTPS requests ? Currently if I remove my update in NodeExecuteFunctions.js file I canât make HTTPS requests at all.
No official solution yet however⌠We have recently hired 3 new support team members so once they are up to speed I will be able to get back to fixing issues like this.
I wonder why the unofficial change isnât fully working, The change itself looked good to me so I guess there are other things to take into consideration with it.
In fact there is a redirection where an overwrite of HttpsProxyAgent is made by Agent in the âgetBeforeRedirectFnâ function so my proxy is not used anymore.
I managed this but I donât really like to âforkâ n8n, it could cause bigger issue in the future (like the one where are currently speaking) and event if I currently able to bypass this Iâm not sure I always could
