So I am using an agent to help collect data on a user in a conversation. it seems the agent is returning all the correct feilds needed in airtable but for some reason it just keeps giving me a consistent “Your request is invalid” At first I thought it was becuase I was asking too much of it so I lightened the load to manually output the other data that it seems to be missing but it hasnt fixed the problem.
the error message is the request is invalid or cannot be processed by the service.
1.65.2 (cloud)
Error: Received tool input did not match expected schema at DynamicStructuredTool.call (/usr/local/lib/node_modules/n8n/node_modules/@langchain/core/dist/tools/index.cjs:103:19) at processTicksAndRejections (node:internal/process/task_queues:95:5) at /usr/local/lib/node_modules/n8n/node_modules/langchain/dist/agents/executor.cjs:486:27 at async Promise.all (index 0) at AgentExecutor._call (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/agents/executor.cjs:478:30) at AgentExecutor.invoke (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/chains/base.cjs:58:28) at Object.openAiFunctionsAgentExecute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/agents/Agent/agents/OpenAiFunctionsAgent/execute.js:75:30) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/agents/Agent/Agent.node.js:373:20) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:722:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:707:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1137:20
